Mirrors
  • Mirrors
    Does anyone know if other model mirrors fit my TLR?
    Thanks!
    I think zx9 mirrors fit
    Originally posted by TLCURT
    Because TL's fucking rock.
      zx9r/zx6r
        All other first generation SRAD mirrors are the smae too.
        96-99 750's
        97-00 600's
        97-01 TLS's
        98-03 TLR's
        99-?? Busa's
        Frank Corona
          The mirrors from this model RG150 bolt straight on,are really lite & look really good,a friend of mine put them on his TL,I'll be putting them on mine when I can find a wrecked one.
          cheers http://www.autobuy.co.nz/motorcycle/...z/results.aspx
            I bought the ZX style mirrors and they look great.
            BUT.. the screws are a little too long, so be prepared to cut off a 1/4" or so, and they fit great.
              Or you could try these sleek real carbon fiber mirrors from Red Racing Parts... Hmmm yummy!
                have you guys seen those carbon ones from tricktape. they are awesome but there only pictured w/ one mounting bolt each! how in the hell are you supposed to mount any mirror w/ 1 bolt!!??
                  if i remember right, there is an adapter that goes from the 2 fairing holes to 1 morro hole
                    I got a set of carbon chicanes. They're sweet as.
                    Easy... they weigh nothing... you only need one bolt but it comes with a plate the same with as the original so that it covers up the other hole.
                      I just searched accessory shops most do mirrors with adaptor plates. I got some Carbon Fibre ones.
                      Click Me
                      go to the catalogue, click find and enter part number 525418 for a better pic
                      Fixed the link. hopefully
                      A pat on the back is only a few centimetres from a kick in the butt
                        I get redirected to this site
                        http://www.ntprocurement.com/
                        TL1000R -99. Yellow/Black.
                          PutteLiten
                          try again think it's right now
                            those RG mirror fit TLR, not TLS, the difference is the mounting. TLR has angled(45?) mounting related to the mirror arm. TLS has 90 decrees mounting related to the arm..
                            Those RG mirrors are nice ones, they look like they are really light...
                            Not to go to extreams with weight, but I got those mirror mounting nuts turned out of of aluminium. original pair of them weighted ~19grams. pair of alu ones 3.5grams... so in two mirrors I saved massive 30grams in total... Not much but the direction is right...
                            to get it in perspective, take 30gram bullet, shoot it 260km/h, it's going to hurt...It weights(energy) guite much when velocity is high...
                            I'll take some pictures and post them...
                            JT
                            JarkkoT
                            quote:
                            Originally posted by tv1000s
                              Originally posted by imwelsby
                              PutteLiten
