passenger seat fixes?
  • passenger seat fixes?
    I'm having problems with a very loose rear seat (can't put my new cowl on, too loose). anyone got a fix, or should i rig a spring to the latch somehow, and call it good.
    thanks in advance
    mo
    '99 TLR, M4, Yosh remap, Box mods,Ohlins rear, Race Tech Ft., vortex clip ons, homemade pegs, custom paint
    '06 KTM 450 smr, '04 BMW R1150GS, '95 kx500 desert bike, '76 RD400 project racebike
    '71 Honda 400 supersport project, 60's Honda c90, '05 GTI, '81 Scirocco S, '93 F250 Turbo IDI
    nice looking bike!
    welcome
    There are lots of fixes what's wrong with it?
      seems like the latch is not returning a fully closed condition. is there a way to tighten the latch return spring? i thought it was a common problem. definitely don't want to loose the hammerit cowl before i show it off. what did you do to yours?
      oh, and thanks
        well i used to have some pics of what i did, but i recently cleaned out some files and seemed to have lost them
        what i did was remove the two nuts holding the latch assy to the sub frame and push the latch out of the way. i took a rat tail file and elongated the holes over to the left (looking down at the bike, if sitting on it backwards) so the latch would have more contact on the cowl hook or the rear seat hook. just file it a little bit. i also put a spring from a ball point pen around the cable to keep it secure in the latch. good luck.
          My suzuki dealer simply fitted a spring to fix the problem with mine.
            i dropped the latch assembly down farther away from seat/cowl by fitting washers as spacers, so i have to push down hard to get it to click, and now it sits tight and i have to push down on the seat or cowl while turning the key to take the seat off now. also bent the metal hoops on the seat and cowl a bit so theyd be more engaged with the latch. and also wrapped some tape around the metal 'peg' on the seat and cowl so they sit snug and don't rattle around.
            this all made them fit tight and got rid of the unsightly gap between the seat/cowl and bike. if none of that makes sense the way i wrote it, i could probably take some pics later on and post them. good luck.
            <font SIZE="5" COLOR="red"><b><center> ~Alien_Tank </center></b></font>
            <hr SIZE="10" WIDTH="100%">
            -see ya!!!
            <BR><marquee BEHAVIOR="scroll" DIRECTION="right" LOOP="25" SCROLLAMOUNT="6" SCROLLDELAY="50"> </marquee>
              all those fixes made good sense. i think i will rat tail the holes, and space down the latch assembly to remove the gap.
              thanks a bunch
              mo
                now that i think of it, i modifyed it a bit more than i listed there above (i've done made these changes in a few different phases). the last time i actually drilled out the existing studs on the metal latch, and inserted new longer bolts into the new holes where the studs were, so i could drop the latch even lower (using more washers). it took me awhile of trial and error to get it optimized, a bit of a pain, but worth it. now the latch sits so low, that i had to take off the rubber grommets on the bottom of the cowl bracket and reverse them so the small part stuck thru hole and out the bottom of the bracket to make contact with the bracket on the bike. otherwise i couldnt push it far enough down. it seems to work fine like this. i think i left the rubber grommets on the seat off completely to get it down far enough, i can't remember exactly, i'd have to go and look.
                -see ya!!!
                  Used duct tape along the top of the rail the latch sits on ta snug her up.
                    but use some 3M tape instead
