http://www.lockhartphillipsusa.com/p...ub3.asp?id=362
Talk about some cool levers
for street or if you don't plan on crashing.
too expensive for me esp. on the track where you wouldn't be able to adjust them other than in the pits, which negates any benefits other than.
AFM #715
i was thinking about getting a pair for the bling bling ,but i was told that you can only use the brake lever it wont work with the hydro clutch on the tillerMY MODS:
TO BE CONTINUED
$190 for 2 levers.. With the $140 shit and bake levers that would be $330 for new levers for the Tl..
Yeah, they look cool but sheez!I've got a huge penis, You've got a huge penis, even Tim over there, yup you guessed it, huge penis. Good, now that that's out of the way, let's go ride
well too bad they dont makem for the tlSebimoto Carbonfiber Bodywork, Zero Gravity D/B dark tinted screen, Carbo tech C/F frame guards, C/F look levers, black Spider grips, M4 Full system (alum), PC2, Light tech C/F mirrors, GeeLong C/F tank protector, 520 Conversion W/ Gold RK chain and 16/40 stealth sprockets, Pedros Gear Position Indicator, Fan switch, Airbox lid.....REMOVED, Probolt Fasteners all Gold. Spare Set of AMA's Larry Pegram #72 bodywork, Gold clear clutch cover, Galfer rear wave rotor, Pro-Tek Rearsets, Flycal6 quick release tank and seat pins, in the black frame club, Vandrivers coerce style sprocket guard, and a killer TLR keychain
Originally posted by Edwin
I can get them for ya'll for cheaper.
Well...a little cheaper anyway.MY MODS:
TO BE CONTINUED
