Two Brothers install help
Ok, this isn't supposed to be this difficult for just slip ons (bolt ons as the case may be) They include a black bracket, just a small rectangular piece with two holes in it, it's supposed to mount on the back side of the OEM pipe mount, facing rearward, and then the new TB band clamps mount to this piece. Well I can't get any of it to line up right, even with all the bolts loose. the TB band clamps are pre bent to fit the oval shape of the canister, If I let them position themselves, the mounting tabs are no where near that new bracket they supply. Those clamps are kinda soft, and I can pursuade them to move a bit, but another problem, is that when you bolt the new band clamp to their black bracket, the band clamp tabs hit the OEM pipe mount, that black bracket needs to be slightly longer, or they should use narrower pipe clamps. I have tried all different combinations, thinking the instructions were wrong, But I can' t get it to go togetherIt's hard to tell from the pics, but The bolts are at a slight angle, so I cannot tighten them, or it just pulls the brackets closer, and jams up.
Tags: None
Another thing I noticed, is that it appears these will tuck in towards the tail like the stock pipes did, I have seen so many that appear to come straight back without angling towards the tail, is this a mod people do to their brackets? or is that just the way the Two Brothers are supposed to be? just like stock.
The reason you can't get it on is because the band clamps go on either side of that rectangular bracket.... one is in the front... the other is in the back.
You are overthinking a simple thing. The band clamp ends do not go on the same side of the bracket.
Maybe its a design problem with the Blue TLR.
You're welcome.
You're welcome.
ah ok I see what you are saying...
slide that front tab under the stock bracket a bit. I did mine a while ago... but I may have done that. Or... take a dremel and grind off the front tab a bit to shape it around the stock bracket. I have to wait until I get home to see what I did.TL1000R: For those who like to drive high speed tanks
When I got mine they had sent me entirely the wrong brackets. 5 mins on the phone and the new ones were on the way. Be sure this didnt happen to you too. Once I got the right ones everything was way easierStupidity is like chlorine for the gene pool.......
Originally posted by SDTLR
When I put on my C-2's they mounted to the stock location:dunno have you tried that?
Originally posted by thesitck
When I got mine they had sent me entirely the wrong brackets. 5 mins on the phone and the new ones were on the way. Be sure this didnt happen to you too. Once I got the right ones everything was way easier.
I looked at mine last night. I slipped the front side tab under the stock bracket...
