Wilbers 3-way shock w/ linkage & RH-adjuster! (pics!!)
  • Wilbers 3-way shock w/ linkage & RH-adjuster! (pics!!)
    My boy TLRR found these pics... I will now only eat Ramen noodles until I can buy one!!!
    How much does it cost? Is it better/worse/same as penske or ohlins?
    RIP - The Pig (Stolen July 2006)
      Dammit.. this will be one expensive winter.
      Shock
      Fork springs & oil
      Rearsets
      Full system
      Brake upgrade
        I beleive its better than Öhlins (special TL-linkage, 3-way, RH-adjuster) and prolly on par with Penske.
        Supersport 600 champion Jörg Teuchert competes with these so the quality is top notch.... I´ll check the prices when I get home but here in Sweden they are less $$$ than Öhlins (which is a Swedish company)... go figure.
          that is perfect for you B/W guys.
          Now the yellow TL's get ALL the Ohlins'
          all the b/w owners will now be know as Wiiiiilllllllbuuuurrrr to me
            Any way you can get another pic that shows the bottom mount bracket a bit better? Thanks.
              ............i need one of those............all Wilbers
                hmm.. dunno, I´ll try.
                  J-Bone:what upgrade of the brake´s are you thinking of??
                  I ordered mine Wilbers 641. today.
                  JE-pistons 12,6:1--Vee-two cams--ported heads and flow tested--Valve race work--Sebimoto bodywork--ISR radial race MC--Wilbers racing suspenion front and rear--OZ HL02--PC bodywork race airbox and ducts--PCII--Nissin 6-pot. calipers--Ferodo CP911 pads--M4 full system tuct in--Pyramid C/F hugger--goodridge braided lines--Double bubble windscreen--Pair valve mod.--Barnett springs -- Factory Shift EVO-kit--Sato "black"rearsets--Graves faringstay--Harris GP Clip-on --Ferodo Axis Ductile Iron Rotors--Carillo con rods.
                    Yepp: Öhlins it is.
                    I packed a few goodies in this picture.
                    TL1000R -99. Yellow/Black.
                      Oh, forgot so mention, look how CLEAN the chain and the rear spocket is.
                      Thats the way they should look like
                        Liten Putte Looks very nice.
                          very cool looking..
                            That shock whit the blue spring would look great on your bike
                            J-Bone
                            Originally posted by TLCURT
                            Because TL's fucking rock.
                              J-Bone
