Thanks
GXSR front brakes on a TLS?
I was wondering if the pre 2003 six piston calipers from a GSX-R1000 would bolt up to a TLS? i know that the TLR calipers bolt up but I wold like to get the gold calipers and the 2003 TLR are kinda hard to find
Thanks'97 TLS, Two Bros CF C5 cans, PCII, air box mod W/ K&N, traxxion front forks, bitubo rear, TLR MC & calipers, Galfer lines, EBC rotors w/HH pads, 17/42, +mod, headlight mod, R1 regulator, Pro-tech frame sliders
'00 TLR, M4 Full System w/ shortened cans, Airbox mod w/ BMC, PCIII, Ohlins Shock, 08 Busa Front End, Scotts Steering Damper, 09 GSXR Rear Wheel, 520 Conversion, R/R Upgrade, Headlight Wiring mod, +mod, gap mod, GSXR clocks, JoE ConverterTags: None
No, those 6-piston calipers are a little different. If you do a search for 6-piston calipers you should be able to find a post from Steve that had most of the 6-piston calipers that fit.
FWIW... I'm using ZX12R calipers (gold anodized).
EDIT: Found it... Click Me...
Sweet, Thank you very much'97 TLS, Two Bros CF C5 cans, PCII, air box mod W/ K&N, traxxion front forks, bitubo rear, TLR MC & calipers, Galfer lines, EBC rotors w/HH pads, 17/42, +mod, headlight mod, R1 regulator, Pro-tech frame sliders
