more power
  • more power
    Am trying to get a little more power to the rear tire on my TLR Have dual Yosh with power commander installed. Dyno'd at 106.5hp and 65 pounds of torque. What kind of trade off, if there is one, will I get if I open up the air box? Open to ideas or advice.
    That Dyno seems really low for the mods you have. Are you running the proper map? You'll need to get a full exhaust if you really want to reap the benefits of messing with the airbox.
    2001 Suzuki TL1000R:
    K&N filter
    Yosh. Box (YAFMS)remap
    OHLINS damper
    +2 AFAM Sprocket
    Corbin seat
    Bitubo shock
    EBC HH Pads
    Memphis Shades windscreen
      106 HP that's horrible 65 lbs. terrible have them check their dyno, you should be making at least 120 and 70
        fastest way to increase hp is to goto another dyno
        should be getting 120 +bhp
          The shop that Dyno'd it told me they could not find the exact map and that was the best they could do. From the replies it looks like I could do much better. Thanks!
            The only other sure fire way to get more power would be to trade it in and get a yellow one Everyone knows that the yellow ones are faster
            http://www.stud.ntnu.no/home/alexann
            If it doesn't make it go fast, stop fast or turn fast, it doesn't have it.
              get your own better map
              http://www.powercommander.com/306-111.shtml
                TL4Life
                Thanks, but am unable to open the damn files. Will try it on another computer.
                  I would agree that the dyno "may" be reading low, and that if you went to another dyno center, you would probably see better results. (They would be different at least, giving you a hint at what's up..)
                  Ask Steve.. He doesn't even call his readings hp.. they're SP.. STEVE POWER's!
                    Re: TL4Life
                    You have to have their software to open their file. The application is downloadable at their site.
                      Shred that readout sheet ASAP zook
                      Welcome too
                        Opening the airways some certainly shouldn't be a bad thing -- let the engine breath. Also, another cheap way to increase your hp/torque is to remove a layer from the head gasket. This will up the compression ratio and decrease the squish area. It's up to you to measure clearances to ensure there's no problems, but I'd almost guarantee there'd be no trouble.
                        Matthew
                          air box mod
                          take a look at the air box mods in the common mods/perfromance mods section. worked great for my bike. breathes much better and makes a huge difference. i agree to check you map, if you open the box you will need to remap. also if you need it I have the map for open air box, k&n filter, TRE and slipones. pm me if you want it.
                          No More TLR
                            Stevepowers rule
                              How and when will I be ready for Stevepower.. Can i down-load it
                              YES it's a V-twin... NO it's not a harley...
