Will my Yosh Box remap need to be reset?
  • Will my Yosh Box remap need to be reset?
    My TLR is currently remapped at +5+5+5 with the Yosh Box. If I purchase a PC for my bike does the map need to be reset to zero before I install the PC with a custom map? I plan on getting a full M4 exhaust.
    2001 Suzuki TL1000R:
    K&N filter
    Yosh. Box (YAFMS)remap
    OHLINS damper
    +2 AFAM Sprocket
    Corbin seat
    Bitubo shock
    EBC HH Pads
    Memphis Shades windscreen
      SD are you sure?
      I'd think it all just depends on how you set the PCII
      If you take the adjusted settings into account while mapping the PCII it should be OK, shouldn't?
      Only prob would be that you won't be able to use an existing map and that you'll have to work one up yourself.
      So I do believe it would be easier to reset it but necessary
      Or am I just totally of the right track here?
      [SIZE=1][B][COLOR=firebrick]
          Ok, so you're nodding "yes".
          Does that mean "yes Schuss, you're right about the remapping"?
          Or rather "Yes Schuss, you're on the wrong track here"?
          Or both
            God Damnit Schuss
              OK, now it's even worse!!
              Now I have questions to which you could be saying yes to
              Common man, help me out of my misery
              Or are you saying yes to my question wether you are sure?
              Wow, I'm totally loosing it here...
                I am 100% sure you need to reset to 0.
                You are way off on your though pattern
                Jason, glad to see you are keeping the bike BTW. She's a good'n
                  OK, now that's cleared out I can to sleep...
                    It does need to be set back to Zero
                      Thanks guys!!
                      K&N filter
                      OHLINS damper
                      +2 AFAM Sprocket
                      Corbin seat
                      Bitubo shock
                      EBC HH Pads
                        Yeah, you want a base stock map in the ECU so you can run PCII maps that adjust the stock map.
                        JASON!!! I am also happy to see you keeping the tiller!!
                        I am wanting a full M4 system too. I can only hoe that it sounds and looks as good as my previous TBR cans.
                        2003 TL1000R
                          Yea, No bikes out there that I really want that are worth replacing old yeller. I'll just make her even better
                          K&N filter
                          OHLINS damper
                          +2 AFAM Sprocket
                          Corbin seat
                          Bitubo shock
                          EBC HH Pads
