Need help changing my spark plugs
YOUR SPARK PLUGS ARE ON THE TOP OF THE HEADS. THE REAR CYLINDER PLUG IS RELITIVELY EASY TO CHANGE. IT IS LOCATED UNDER THE GAS TANK/SEAT. YOU WILL HAVE TO REMOVE BOTH TO REACH. THE FRONT IS DIRECTLY BEHIND THE UPPER RADIATOR. SO IT WILL HAVE TO BE REMOVED FROM IT'S BRACKET. I HAVE FOUND THAT A NORMAL PLUG SOCKET WILL NOT WORK BECAUSE IT IS SO DEEP IN THE HEAD SO YOU WILL NEED THE SUZUKI TOOL KIT THAT CAME WITH YOUR BIKE. GOOD LUCK, I HOPE THAT I HAVE BEEN ABLE TO HELPBeauty is only Skin Deep, She's pretty on the inside!
The rear is easy to get to...remove seat and lift tank. On the front...remove the fairings and you will need to unbolt the radiators. Keep the hoses connected. Once they are loose just move them out of the way to get to the plug.Common sense is not very common.
Gotta take off the horn for the front. Only remove one of the bolts on the bottom of the radiator and just loosten the other so it can be moved up and down easily.2001 Suzuki TL1000R:
K&N filter
Yosh. Box (YAFMS)remap
OHLINS damper
+2 AFAM Sprocket
Corbin seat
Bitubo shock
EBC HH Pads
Memphis Shades windscreen
I just gave my bike the complete go over, fluids, plugs, cleaned the BMC etc. What a pain in the balls the front plug was. I had to take the fairings, air rams, etc completly off to get at the radiator bolts to lower it enough to get at it.
My only fear now is when the BMC dries and I replace it, the thing won't start and I have to do it all again
That would royally SUCK! Please tell me I don't have to do all that to set the TPSI've crashed both, and hurt myself worse on bicycles then I have on motorcyles!
Originally posted by polarpc
Speaking of iridium plugs....What are you guys paying for them? I asked my dealer, out of curiosity, what they get for them and it was $8 or $9 per plug. For a stinkin' spark plug? C'mon.
Re: Need help changing my spark plugs
if you order the Iridium plugs from advance auto parts the are about seven bucks + tax. the part number is CR9EIX (NGK). the stock number for advance is #3521.Last edited by ruffryda1961; 06-05-2008, 03:46 PM.
