The noises at the moment sound very much like a missing tooth or two. It only makes the noise when the clutch is released, stationary in gear with the clutch in makes no noise. It seems only when the shaft from the clutch is spinning the noise will occur. In neutral with clutch released will make the same horrible noises.
Firstly and most importantly, can the gearbox be pulled apart without pulling down the engine too? Does any one have any idea on what part will be broken - are the boxes easy to pull apart? Are there any special tricks? Has anyone had this happen to their TL? and how expensive r gears?
Many thanks
Ben
