Install Yosh ex.
  • Install Yosh ex.
    The Yosh full system call for a new exhaust port gasket.
    Is this the front cylinder or rear cylinder?
    Both
      Full system only needs a new front gasket. If you are careful you can reuse it. I put the full system on with only 700 miles on my bike. The old one worked great.
      Yosh RS-3 full system, Top Gun Undertail, Carbon hugger, PCII, 41 tooth rear sprocket, Ohlins Steering Damper, Corbin seat, JoeV Mod, K&N filter, Ivan's TRE, AGP front/rear brake lines, Barnett springs, ZG DB Smoked Windscreen, No-cut frame sliders, short stalk 2-way front blinkers, manual fan switch, Yellow/Black grips
      Other rides-2008 Civic EX-L, 2005 WRX STI (SOLD), 1978 Nova w/406(FOR SALE), 1988 K2500
        if you reuse it, make sure you put gasket sealer on it, ya wouldnt want to mess around with it after you get it all together...
          I tried to install the exhaust. I cant stop a exhaust leak on the rear cylinder where the yosh clamp to the stock rear pipe. Is there a gasket that Iam missing? I know that the stock pipe had one. HELP!
          T-Bone
            bait...if i remember right, the rear gasket gets tossed when going full yosh. mine sure as hell wouldnt fit. no leak here
              Also when I had all of it installed why is the left pipe longer then the right. Did anyone have this problem.
