Who has a pitbull newfropnt stand?
  • Who has a pitbull newfropnt stand?
    I just got one, and looking at the plastics under the steering stem.
    Did you remove the whole thing, or cut out the appropriate hole/slot. If you removed, did you notice any change in running temp?
    Thanks
    Nate
    Galfer SS lines, LE reworked forks and Penske rear, IRP axle spacer, frame sliders and rear spools, custom airbox, block off plates by MFR Inc., custom undertray, Extreme Graphics Top Gun undertail w/ Navy's dimmer, ZG DB dark, Scott's steering damper, Yosh bolties, PC2, DID 520ERV2, 17 SS & 41 AFAM, Galfer rear wave and other stuff to come!
    You have to remove the black plasic under the lower triple. Then you will see the hole that the shaft goes into ( that sounded funny )
    No, no difference in running temp.
    <img src="http://i12.photobucket.com/albums/a203/TJLeviste/sig2resized.jpg" alt="Image hosted by Photobucket.com">
      If it doesn't work out for you, you can sell me that stand
        I left the plastic in and drilled a hole in it.
        Also , I found that I have to push the stand toward the bike at a slight angle to avoid scraping the top of the fender. Once the pin is engaged , then slide the stand around to the front.
        Experience - That thing you get the moment AFTER you needed it.
          I took the thing off. I couldn't imagine taking it off and putting it back on everytime I used that stand. Didn't notice anything different in temp or anything else.
          Jay
          RUN!...It's Twin-zillaaaaa!!!
            recently got one for the tls.
            great unit. the horn is the only thing that was in my way.
              gonna look for a diff place to mount the horn
                Dem sure are some nice stands you got der boy!
                "If you can't solve it otherwise, get violent."
