Safety wiring
Safety wiring
Are there pre-drilled drain/fill plugs available somewhere? I figure if I'm going to have to buy several 1/16" drill bits I might as well try to find some pre-drilled bolts instead.TLXR Project Bike:
Donor '99 TLR, PCII, K&N custom filtration, Sharkskinz Airbox/Ducts, Sebimoto carbon fairings with dual projectors, QBCarbon tank and vented front fender, M4 Ti/SS Full Exhaust, BST carbon rims, Pirelli Supercorsa's SC1/2 (190/55 rear), complete '03 GSXR1K front end, AP Racing radial mono-block calipers, Brembo Radial M/C, EBC 320mm Prolite Supersport rotors, GSXR1K rear caliper, Galfer SS lines all-around, CFM clip-ons and rearsets, 520-conv w/DID ERV2 chain, Ohlins rear damper, Ohlins Steering Damper, ZeroG DB screen, Graves fairing stay, Lightech true carbon/Ti mirrors w/custom brackets, Ti caliper & rotor bolts, plenty of black Al bolts, Eurobikes carbon hugger, POR-15 sprayed frame, custom Al undertray, custom quick-release tag bracket, switchable TRE, custom 1/2" subframe risers w/Ti hardware, some other stuff I'm likely forgetting...Tags: None
