undertail exhaust design give thoughts
ok i just scored a vanace and hines can looking to make a 2 into 1 undertail set up i figure i will come up the sides and under the seat and have a cacther waiting for the 2 pipes and go into the one can. any thoughts on how it will work got my guy doing it tommorow morning and i will have pics but for now i need thoughts on how this will work.Tags: None
TLRMAN did a 2-1 undertail and didn't lose much power.
T2nv did a 2-2 undertail and lost lost of power
Have you looked at Tornado systems from Austrailia? They look pretty cool with either pipe running outside the swingerTLOTM:
Originally posted by TL4LIFE
TLRMAN hasn't done any engine work to his? I heard his makes @140 RWHP? That would be remarkable without any internal work and his rear muffler looks bigger than one vance and hines muffler
He has a custom can, I never said V&H
Who said 140untill Lance shows up, Im callin
my guess is unless that v&h can is hollow, your back pressure will be screwed up. 2 into 1s usually have a pretty big can from what i have seen
i can't do the new r1 look
i tried every which way and i can't do it the swing arm hole is not big enough.it probaly will look like the one pic on my other post with a pipe on each side. i think that is a cool way to do it and i was hopeing that doing it this way i wouldn't lose any power and still have that cool look.
Originally posted by SDTLR
Have you looked at Tornado systems from Austrailia? They look pretty cool with either pipe running outside the swinger"I spent most of my money on Scotch, women and cigarettes. The rest I just wasted"
...had to do it.TLXR Project Bike:
