So now i have my $1000 TLS, the numbers on the frame don't match the numbers on the side panel and the title isn't in yet so theres NO tellin what numbers are on it..
the frame has been rewelded just in front of the radiator mount behind the frame neck along the bottom of the frame.. it looks professional, but its still a weld..
the engine has every valve in it BENT from the guy workin on it himself.. (hence the question last week about why the motor wouldn't turn all the way over without hitting something inside)
soooooo my one week long project has now turned into my winter project...Which is fine because it was going to be my beater bike, but now I'm going to go all out on it like I did my F4i.. this summer I'll put the F4i up for sale and get a different bike as my second bike..I really wanna do this right.. from the engine, to the frame, to the paint job, to the braks and suspension.. all done ONCE and done RIGHT! I was hoping a few of you might have some advice for me.. heres the questions I have.. I've used the search function numerous times but this is more opinion than anything else..
If theres anything YOU would do to it while its strung out in boxes all over my garage, post it.. i wanna hear about it. once i finish it, i wanna be DONE with it..
1.) Should I POR the frame or polish? The body work is going to be sprayed "triple-jet black" with a "glamour gloss" final coat put on.. so would it look better polished or blacked out? you photoshop wizards would come in REALLLY handy right now!
2.) Is the digital gauge swap worth the effort? Will it mess with the codes?
3.) Whats the advantage of a TLR swingarm? It came with one (extra) but it doesn't look like its a straight swap..
4.) The akro system I have has turned a hideous color on the pipes and the carbon looks completely baked and the gloss has all but come entirely off, what should i do? is it rebuildable? Can i use different cans (M4 or Yoshi, something like that) with the Akro Headers?
Any advice on where I should go with my project is much appreciated..it only cost $1000 so I've got about $4200 left to spend on it.. not that i will spend all of it on this project though!
My wife would have my ASS!
So basically, if you had a free TLS and $4000, what would YOU do?
