stock wheel weight?
  • stock wheel weight?
    Does anyone know what the stock wheel weight is with rotor and sprocket by chance? Thanks!
    link
    Pull those rotors and take a walk into the produce section.
      rear rim/sprocket/cush weighs 32.6 pounds with an M-1 180
      Supposedly the M1 is 1lb lighter than a stock 190:dunno
        C'mon SD! Don't be so lazy. Yank that tire off and do it right! Yeesh...
        TLXR Project Bike:
          Guys, take a look in the pics section!
            No way bro, this one goes on the wall in the garage
              making a clock out of it?
                think you would be better off with after market wheels if you wanted to shave weight. seriously what did you do, back into something OH I get it probably rear ended you make it out OK
                No More TLR
