Subframe advice needed
  • Subframe advice needed
    I got a picture of my "modified" subframe.
    Question.
    As you can see, the middle holds are missing (broken). Do I need to fix them or can I ride without them witout any problems?
    THey are broken on both sides. (why?? becasue the previous owner is a slob... If he had done the mod right, it would have hold better...)
    I have the stock Hump.
    TL1000R -99. Yellow/Black.
    I forgot to say htat I will remove the "exhaust braket" because it´s in the way for my new undertray.
      Just, incase I was a bit unclear. This is how the Subfram will be modded.
      And, since it´s so damn expensive to weld Aluminum I don´t plan to reinfoirce it again.
      And, No - I don´t plan to have passengers on the TL. (Have no rear seat)
        Double posting questions
        That's a new way to whore
        Sure, that will be plenty strong for one PL, why no girls on the back or do you put them up front
        What are you using to hold the cans
          SD. Noone but you, anwered last time,.
          So, you FORCED me to post hoe...
          I plan on building "can support" that goes from the passenger peg holders and down to the cans.
          Going to get some 1.5mm (maybe 2mm) aluminium and do a pair on my own. And, if it should feel a bit unstable, I can always make them double.
          Hmm, cant find the picture on this computer. Well, this picture show the general idéa.
            Good Christ that thing is hot
            I got no backup on that thread
            c'mon someone has to agree whit me sometimes:dunno
            Feel free to whip up a set for me if you have the time will trade for TLP stickers
              Sure! will do.
              Guess I have to get moving and buy the alu then...
                  arn't those just the helmet holders that are missing . file that crap down and don't worry about it...........good idea for the exhaust holders. i'm sure we'll hear all about them, right?
                    Oh, BTW SD. Can´t do it this month. I´ve $60 left on the bank...
                    Got a little issue with my car... (at the work shop right now, and is going to cost something like $400... )
                    Oh well, shouldn´t have bought a new computer this month...
                      Uno, sure. I will tell everyone about the can holders, when Im done with them
                      No, there are real screws under the helmet holder. But, maybe it´s like you say. They might be there to ensure the helmet wont drop to the ground. Or something.
                      Well, welding Alu is s**t expensive where I live so im pretty sure I will do this mod and hold my thumbs.
                        oh...........now i see. you were right . i guess they had a race solo tail section on. the solo tail doesn't use the side bolt. here is a stock photo
                        EDIT: solo tail does use that bolt location
                          That bike is bad ass
                            HOT!!
                            2003 TL1000R
                              Yeah, that bike is cool. I wonder who it is...
                              I really don´t remember where I got the picture. I saved it because I wanted the "can holder".
                              Easier to look at how someone else have done before. Unessesary to invent the wheel every time...
