one down, one to go
one down, one to go
It still needs to be properly polished, just been sanded / autosolled so far. Sanding the machine grooves out is the most time consuming - it took about 20 minutes to smooth the rims out for polishing after about 5 hours of sanding with 320, my thumb and index finger are shagged! I ground the writing off of the spokes and painted the inners with black gloss. Good thing I had nothin better to do on nightshiftcumbaya sparky!
Tags: None
Looks sweet, but what a bitch to keep clean... Keep up the hard (I mean good) workJust a few mods:
looks great..........what did you use to paint it black? i know it was paint, but what kind.
I put it on the bike this morning, I'm not sold on how it looks - I might just paint em both all black yet! i'll wait for a bit and see if it grows on me...the cleaning bit has me worried too. I think once they're polished right up they'll be harder to keep clean, but easier to clean, if you know what I meanWhile they're still a bit flat I think they'll hold crap a bit more - might look into some clear coat too, will have to nice and strong tho!!! The black I used was - wait for it - a rust protector! On the back of the can it explains that it is formulated to bond directly to metals without the use of primer, and it specifically lists aluminium. I used a crap paint stripper that only really managed to take the top layer off the original paint, but after prepping left a nice porous base to paint on. I think if all the paint was removed the sanding job would have been alot easier. i have give the paint a good blast with a pressure cleaner and none came off, but I'll have to see how it goes on the road, but I find most of the rocks and crap hit the outers and not usually the spokes. Time will tell
cumbaya sparky!
I like the look of polished rims. Not so blingy like chromed rims. Plus, after seeing cracked rims on an R1 after getting them chromed, I just don't think it is safe. If your worried about maintenace, buff the wheels real good, and coat them with some clear coat. No more maintence.'97 TLS --SOLD
I know a guy who polished his back wheel with it on a stand. He puts it in 6th gear,lets it idle, and uses the sandpaper like a lathe and works his way down to a fine grit. It looks like chrome when he is done. He is making a stand for the front that runs off an electric motor to spin in. He said to be careful on the sprocket side if you like keeping all your body partsEveryone dies but not everyone lives
hey there mista eddie! if you put your avitar as the back of your bike everyone will know who ya arerighto heres a piccy on the bike! I took so many good pics today! If ya wanna see em they're in the members gallery
I used 1200 but I probably didn't sand as much as I could have... might just borrow your mates idea there Stabber... between that and the guy across the road having a bench grinder/buffer (I never could understand why you would want to grind your bench...) I should end up with some super shiny rims!
