valve springs
  • valve springs
    anyone know of a god set of after market valve springs that do not have the high failure rate that our stock ones have? gonna replace all when I service this winter and want to upgrade while in there. also any sites that sell them would be great. Does barnett have any? I really like their clutch springs, they have worked great.
    No More TLR
    How many valve spring failures do you know of first hand? I have not heard of any. If you are going to use stock cams they should not be a problem. If you are going to a different cam your options are limeted. I use a spring made for a Busa and had bases custom made.
    Art/Wy
      I guess i am confused about the springs that make the TICKING sound when they break (common occurrance from what I have read). maybe someone could clarify this for me I was under the impression they were the valve springs.
      No More TLR
        Man it sucks! And you even tried to keep up so hard yesterday too! LOL
        kidding!
          Valve Springs
          I would call them the sissior gear springs. I would call those a normal point of maintance to be replaced. Any time you are adjusting the valves just replace them. It only takes a few miniuts.
          Art/Wy
            so if I am going to remove the scissors gears and auto decpmpression will I still need to replace the springs?
            No More TLR
              can the starter motor take the extra stress by removing the decomp setup and be reliable longterm
                no, the springs will be removed also
                  I haven't heard of starter motor problems at all -- bump-starting could be more difficult though
                    Valve spring failure aint all that common, happened to me thou, and so far i havent heard of anyone else's tl s or r dropping a valve, trust me when it does it sucks real bad.
