sprocket was not tight
  • sprocket was not tight
    well at 23K on my '01 TLS, my chain has finally had it. I had read about some people's adventure in removing the counter shaft sprocket and fully expected to have some of the same issues. A few months back, I was helping a buddy with his Speed Triple, and we finally resorted to buying an impact wrench after everything else failed on his.
    on Sat morming, I decided it was time to attack mine. First, I had to take off the plastic cover of course. Next was that little hex bolt on the outiside of the sprocket and it even put up a little fight , but came off pretty easy. After that, I get out my largest rachet bar which happens to be my torque wrench. I set it up to the maxium torque and get my self mentally prepared to put my 230lbs to use for once. So 1, 2, 3, turn - bam, I'm laying on the ground, the thing turned so easily.
    Okay, so now I'm sitting there going, man, how long has this thing been loose. How loose is it? Well, after tightening it back up, it wasn't as loose as I initially thought after I fell, but, it sure wasn't what it should have been?
    Anyone else find their counter shaft sprocket loose? May be something you want to check as I never did. Whats the recommened torque on it?
    I am still waiting for my new sprockets to come in. Hopefully today or Tuesday.
    BlueLghtning
    2001 Suzuki TL1000S (sold April '05 )
    2001 Suzuki SV650S
    2002 Yamha FZ1
    2001 GSXR 600 (track)
    1983 Yamaha Venture Royale
    My photos
    since you used a tq wrench, what was it set at?
      Well, I don't know since I had the Torque wrench at a really high setting, but it couldn't have been more then a few ft-lbs. I probably could have broken it loose with a little bitty rachet with out much effort.
      BlueLghtning
      2001 Suzuki SV650S
      2002 Yamha FZ1
      My photos
        Got this off another TL website......Engine sprocket nut 83.0 ft.lbs
          83 sounds like a bit to much since the thing is splined you only need enough tq to hold it on. 50 ft/lbs should be more than enough and with the locking washer you should have no problem.
          RIP Ron
          Sept. 12 2004
            I just checked and mine calls for 61 ft lbs or 85 NM.
            RIP Ron
            Sept. 12 2004
              You know you're not meant to use a torque wrench for loosening really tight nuts... gets 'em inaccurate real quick...
              I bought one of these 24 inch flex bars for about $30.. use it for everything. Tightening wheel nuts on the cage, personal security device.. even used it and the starter motor to bust the bolt off the harmonic balancer.
              Used to ride a '01 TLR
                yeah not the smartest thing in the world I have one of those on my shopping list!
                BlueLghtning
                2001 Suzuki SV650S
                2002 Yamha FZ1
                My photos
                  I had 83 as well (manual)
                  TusherTLR
                  gear:
                  stuff:
                  Joe V mod, Pair valve removal
                    Is there any kind of lock washer or cotter pin on that thing. does it list any other values? could it be a mistake and be 83 Nm?
                    RIP Ron
                    Sept. 12 2004
                      I replaced mine at 22k and it was tight they used a bunch of loctite from the factory
                        we replaced the front sprocket on my roomies 02 busa. 14k on her, and it wasnt too tough. but i held the bike as he cranked on it just incase. there was enough loctite on it.
                          if so, they made the same typo in the tls manual
                          83 sounds right considering the thread pitch and the fdact that both the threads and nut are steel
