matt
Who has an alarm?
I have one, had someone install it for me. It went under the cowl with speaker under there too. Not too much room to put it anywhere else and with the temps these bikes run i dont htink the alarm could handle it anywhere else.I see Dead People...............
No really,i see them all the time. I put them in my ambulance.
when it goes off can you still hear it pretty good. mine says that it puts out a 120db sound, but it also says not to have it completley enclosed either. i think that's where i'm gonna put it though.
mattmatt
Don't have an alarm, but I would if I had to leave my bike outside for any length of time. Would the speaker fit in directly behind the headlight assembly?TLXR Project Bike:
got one ...called Cheeta. mounted it inside the left rear cowling and all the wireing is routed to just behind the tailight. 125db, ing cutout and the markers flash when activated. Also put an master switch on the power so when it's stored for a wile it wont drain the batt.Ohlins rear,Hyperpro/Traxton front, PCII,6-pot front w/SS lines, Airbox mod, High mount exhaust, Clear tailight, Sliders, Carbon front/Hugger, Scotts, Helibars, K+n, Manuall fan sw, EBC HH Pads, 17/42, O2 Sensor w/gauge....list goes on
