Goodrige Lines
Goodrige Lines
I just got my Rear Goodridge SS line for the TLR. Right off the bat I notice that the line is about 6 inches longer than stock. I double checked the Goodridge box, and the part # is right for the TLR. Is there anyone running the TLR Goodridge SS rear line? If so, was yours the same length as stock. It sure will make it route wierd being that long.X-TLR owner
05 Black R1, Yosh TRI-Oval Carbon slip-on's, Fender eliminator/mini signals, smoked lenses, Shogun sliders,
And the need, the need for speed....Tags: None
Hmm, sounds bad. Better ship it to me just to be sure.TLXR Project Bike:
Looks the same
Yeah, that pic looks to be the same as what I received. If I wasn't running a hugger, that would be trouble. Thanks...X-TLR owner
WOw....
My kevlar set fit perfect.. I would call them and have them double check that it's supposed to be that long...I've got a huge penis, You've got a huge penis, even Tim over there, yup you guessed it, huge penis. Good, now that that's out of the way, let's go ride
