Have narrowed it down to three options.
TLR gearing poll
TLR gearing poll
So Im getting a 520 conversion kit (the group buy) and cant decide on the gearing... help me out.
Have narrowed it down to three options.12617-4145.24%5716-3919.84%2516-4015.08%19Other (explain why?)19.84%25PCIIIUSB::CZ wheels::Akra f/s custom cans&hangers::Bitubo shock::GSXR750 K4 legs::R1 calipers::GSXR K2 rear caliper::ExtremeTech damper::Race rearsets::Joe V mod::K&N filter::Van's CCC+PP::Barnett springs::GiPro ATRE::1/5 throttle::C/F mirrors+hugger+fender+tankprotector::LP screen::mod subframe w/ gap tray::undertail::flush indicators::Van's rear cup::Brembo 19x18::Braided lines::Galfer wave rear rotor::Speedking mod OEM rotors::Van's ecc::WC clipons::520 @ 16/40::Van's spr cover::TWM cap::Tags: None
I have 15/45 but if I were you I qould go with either the 16/40 or 16/41. I've ridden one with 16/40 530 chain, it was much better than stock but still could have used alittle more snap when taking off.
You could even go a 15/38 which would help you maintain the lower weight gained by the 520. Lower front will get you even more lost weight and keep you from putting a larger on the rear adding some of the weight you just took off. something to think about. Gearing wise this will put you between the 16/40 and 16/41.RIP Ron
Sept. 12 2004
Most of the TLR's that I know go with a 16/41-43 setup...
(+2 or +4 on the rear sprocket)Just a few mods:
i've only ridden mine that has the 17/41 combo. i like the way it feels. not too abrupt or jerky, better wheelies too. 16/39 would be good to
I'm going with 17/40 with the 520 conversion simply because I really don't need the extra acceleration and would rather have the top end.TLXR Project Bike:
wow, thats agressive. stock is 17-39
would 16-40 be too much.. ? :dunnoPCIIIUSB::CZ wheels::Akra f/s custom cans&hangers::Bitubo shock::GSXR750 K4 legs::R1 calipers::GSXR K2 rear caliper::ExtremeTech damper::Race rearsets::Joe V mod::K&N filter::Van's CCC+PP::Barnett springs::GiPro ATRE::1/5 throttle::C/F mirrors+hugger+fender+tankprotector::LP screen::mod subframe w/ gap tray::undertail::flush indicators::Van's rear cup::Brembo 19x18::Braided lines::Galfer wave rear rotor::Speedking mod OEM rotors::Van's ecc::WC clipons::520 @ 16/40::Van's spr cover::TWM cap::
Originally posted by freakinheat
17/41. Are you going racing? Why the 520 conversion. Lower life span.PCIIIUSB::CZ wheels::Akra f/s custom cans&hangers::Bitubo shock::GSXR750 K4 legs::R1 calipers::GSXR K2 rear caliper::ExtremeTech damper::Race rearsets::Joe V mod::K&N filter::Van's CCC+PP::Barnett springs::GiPro ATRE::1/5 throttle::C/F mirrors+hugger+fender+tankprotector::LP screen::mod subframe w/ gap tray::undertail::flush indicators::Van's rear cup::Brembo 19x18::Braided lines::Galfer wave rear rotor::Speedking mod OEM rotors::Van's ecc::WC clipons::520 @ 16/40::Van's spr cover::TWM cap::
Originally posted by tl1000lasse
Guess the slower/weaker B/W can use all the help there is too get
Originally posted by tillerboy
I went riding with a guy last weekend that went to a 18-49 on his TLS. It was one hell of a wheelie machine.TLXR Project Bike:
Longer chain
larger front sprocket
larger rear sprocket
He probably lost 2 HP to the rear wheel with that set up.
Would be much better off with a 15/ 41 or 15/40RIP Ron
Sept. 12 2004
and a shorter wheel base because of the larger back sprocket requires the tire to be closer.... (easier wheelies)2000 Race only TLR - Accel. Tech built GSXR1K forks w/triple, calipers/pads - Braking Wave Rotors - Full M4 (carbon) - Ohlins damper - Ohlins rear - pirelli tires - Graves fairing stay - Race tail complete with sub-frame - PCII - BMC filter - full Air box mod - Body Double race bodywork - GSXR1K front fender - Galfer/Goodridge lines - Woodcraft rearsets - complete - Woodcraft 50mm clip-ons - Complete front and rear brake levers w/ pazzo short levers red - Tre-Mod + Mod
