Do gixxer 1K forks fit in the TLR triple?
yes but your gonna have to change the springs due to the weight difference.MY MODS:
TO BE CONTINUED
Re: Do gixxer 1K forks fit in the TLR triple?
Originally posted by HandJuice
Do they?
At least not the lower clamp. I seem to remember a few guys doing the mod and either using the 1K clamps or getting shims made for the TL lower clamp.
the 2001, 2002 G1K forks will fit the TL. you would also need gixxer front fender and calipers. the caliper mounting points are closer than on the TL forks. i have had G1K forks on my TL for over 5K miles of track and road use with no problems. i did the swap because the G1K forks i got had already had stiffer springs and valving put in them that matched my weight. some guys say the lower triple from the TLR is too large diameter for the G1k forks. they may well be right, but it is working for me with no problems at all.selling: TLR ECM, Swingarm, Wiring Harness, Rectifier, Triples, Sidestand,
Ok but can you use your front wheel?Attack rearsets, L/E Penske shock, PCll, Ivans TRE, Akrapovic evo
system, goodridge kevlar F/R brakelines, wave rotors(front and rear), EBC HH pads, BMC air filter, Joe-V airbox mod, GP500 double bubble screen, clear clutch cover, no cut frame sliders. brembo radial mastercylinder, Sebimoto race fairings with custom headlight and taillights.Front axle sliders(vandriver)
and a hell of alot more to come......
SERIENSPORT #604
Sponcers:
lockhart philips
sebimoto
akrapovic
www.elvis8310.gixxer.com
