Semper Fi
Not new
Not new
Hello TLP just wanted to let yall know there is a new member on the board. Now I am not new to TLP I have been a registered user from March 02 but have forgotten my username (it was something like snipertlr) and have been a blood sucking lurking leach from that point on . So flame away. I will how ever be in every thread that I can be. See yall around.
Semper FiTags: None
welcome.............again
welcome!
So, got any pict of you sweetheart??TL1000R -99. Yellow/Black.
Welcome... again?Kim
CCS AM #507
Twilight Racing
welcome again i guess.lets ee how many post you will go through b4 you forget your a member
MY MODS:
TO BE CONTINUED
Originally posted by TL4LIFE
Welcome
Shoot away, HI to IN that'd be a big scopeJust a few mods:
