TL Tankslapping
TL Tankslapping
Hey all, I've got a question for all you TL gods. I have a friend who put a 97 TL engine into his 98 frame and he now is encountering tank slappers at 115 mph, the harder he accelrates, the more violent the slapper. It happens exactly at 115, not before. I was wondering if anyone else has ever had the same thing happen, if you think it's caused by the 97 engine, tire mis-alignment, etc. Thanks for your input in advance.Tags: None
:dunno, I'd be re-checking the wheel balance, both front and rear, but especially the front, also the fork set-up, equal lengths through the clamps, same rebound / compression and preload settings on each leg.
He may have pulled the frame out of whack by having a spacer in the wrong place or someting too with the changeover.."I spent most of my money on Scotch, women and cigarettes. The rest I just wasted"
Originally posted by GSXR Jake
I know his biggest concern is that the problem has something to do with the engine, because he never had any problems with it when he had the 98 engine in there.
He's put something back together incorrectly, tight chain, mis-aligned chain, mis-aligned wheels, wheels out of balance, gave something a knock when disassembling / reassembling, bent the frame, list goes on and on.
A rear end problem can cause front end symptoms, but I'd go over the front end again, and again. And do a visual on the rear wheel and chain tension.
Tell him to go and buy a ball of string and double check the wheel alginment."I spent most of my money on Scotch, women and cigarettes. The rest I just wasted"
Ok, we checked the wheel alignment, it's good, wheel balance is ok, motor mount bolts are tight. The only what if we have is the rear tire. The tire is a race pull-off, and right now I think it's cooked because it is rock hard! It is also worn more to the right side than the left. I figure that this would make the bike trail funny, does that makes sense?? Again, thanks for the input, and any other info you guys have is appreciated.
He allways encounters a slapper at 115
Is it just me, or is he lucky to still be riding? I have never had a slapper nor do I ever want to experience one... from what I know about them is that they are very VERY hard to recover from.
Not to raise the BS flag too soon, but it just sounds fishy to me.If trees could scream, would we be so cavalier about cutting them down? We might, if they screamed all the time, for no good reason.
tell him to add a govener on it and set it to 110...2000 Race only TLR - Accel. Tech built GSXR1K forks w/triple, calipers/pads - Braking Wave Rotors - Full M4 (carbon) - Ohlins damper - Ohlins rear - pirelli tires - Graves fairing stay - Race tail complete with sub-frame - PCII - BMC filter - full Air box mod - Body Double race bodywork - GSXR1K front fender - Galfer/Goodridge lines - Woodcraft rearsets - complete - Woodcraft 50mm clip-ons - Complete front and rear brake levers w/ pazzo short levers red - Tre-Mod + Mod
