  • 180
    I guess there's a first time for everything...SD has gone from 190poser to 180racer
    I'm impressed so far :dunno I'll have more info after the Friday morning Palomar run.
    It looks so small :dunno
      Side shot Bah, show us the 180, worried about your chicken strips?
        Now you go and add a rear end shot! No hugger clearance problems with the taller tyre? Lube the chain.
          The hugger fits perfectly, What do you mean lube the chain:dunno I just did 10 hours ago:dunno
          Those strips wont last long trust me
            Nice wiener tire!! Dont they put 180's on 600's?? hahhahah!!
            j/k
            BTW: What hugger is that??
            2003 TL1000R
              yeah, ,and dont those 600's handle a lot better than we do
              01 Tlr
                so, you did get the sportec.....nice job.
                  I'm back ta the 190 in the pilot and love it!
                  180's I had
                  pilot race - loved it
                  207 gp - not a big fan
                  207 street - not a fan at all
                    I'm doing the same...soon. Droppin' the Dunlops and going back to the Michelin Pilots Sports
                    Jay
                    RUN!...It's Twin-zillaaaaa!!!
                      once you go 180.. you'll never go back.. i just went with 180 M1s... simply amazing
                        hey sd did you paint your brakes or are they zx12 brake
                        MY MODS:
                        TO BE CONTINUED
                          the brakes are stock 2003
                          It's a Pyramid hugger from www.streetfightersbydesign.com
                            180's I had
                            Next tire you should test is a Pirelli SuperCorsa 180/55. Best tire I have EVER had!
                            (I ride SuperSoft though...)
                            Or, Mezler Rennsport RS1, same same, different name...
                            Im serious! You really should test the SuperCorsa!
                            Personally, I HATED the Pilot Sport. Took forever to get warm, and during that time, I usually have som interesting moments I could be without...
                            It does nice burnouts though...
                            TL1000R -99. Yellow/Black.
                              I kinda like cold slides, use ta race a lot of mx, still ride a lot
                              Once warm they are da shit, much better than the 207 in a 180 for me at least!
                              I have heard good things about the corsa 55 though. Have ta burn through the pilots 1st, under 1k and the man is gone on the rear.
