When I was out for a ride on the weekend with a fellow TLR owner, we noticed that his chain was WAY too loose. I knew that I had recently adjusted mine...after installing the 16t front sprocket
Once I loosened the axle bolt and spacer lock nuts, I gave the adjusting screw 1 flat spot looser. I then felt the chain, and it felt too loose, so I put the adjusting screw back to where it was. It still felt too loose! So I put the axle nut back on, and torqued 'er up...checked the chain...way too tight!
Anyone else find this, or is mine just wierd?
