Rear exhaust gasket question
Anyone know if the rear exhaust gasket is installed over the "spigot" looking thingy where it meets the rest of the exhaust -or- is it all the way in at the header area, just like the frontSOLD! 2002 Suzuki TL1000R -Blue/White
Tags: None
Well kinda both .......The rear has a small 6"-8" part that is bolted to the motor just like the front with a gasket against the motor. The rear part of the header slides over this with a round cylinder type gasket and a t bar clamp. Hope this helps you do have to mechanical joints and two seperate gaskets.
Lance Seattle, WA.
Hey stabber, was the the gasket near the motor or near the spigot that connects to the rest of the header?SOLD! 2002 Suzuki TL1000R -Blue/White
Here's a pic Crusher. I have a new gasket (part #6) on the way from Ron Ayers. I was going to replace it if I needed to when I get the M4 from you . If I don't need it I'll send it to you for free so you can replace it on the system I sent you if need be. (doubt you need a new one).2001 Suzuki TL1000R:
K&N filter
Yosh. Box (YAFMS)remap
OHLINS damper
+2 AFAM Sprocket
Corbin seat
Bitubo shock
EBC HH Pads
Memphis Shades windscreen
I don't even have that #6 gasketDoes it sit outside the pipe, then you tighten it down with the clamp?
I think it sits between the clamp (part #4 in the pic) and the pipe......I think.......All I know is I sent you everything that was on the rear header that came off when I untightened the clamp. There was nothing else in the small pipe that remained hooked to the header.2001 Suzuki TL1000R:
K&N filter
OHLINS damper
+2 AFAM Sprocket
Corbin seat
Bitubo shock
EBC HH Pads
If you have an aftermarket exhaust full system you will not have that gasket JFYI. My M4 is slip fit with a clamp and I think the yoush system is the same way. If you still have the stock header you should have that gasket.
Lance
