does size matter
does size matter
ok guys get your mind out of the gutter my question is about the crank case cover or the clutch cover which ever one you pour the motor oil into my question is this are the tls and tlr covers the same size or is there a difference please help thankswhat do you get when you mix crown and coke? drunkTags: None
The right hand cover is the same,
If you fit a TLR clutch to a TLS (97-98 5 springers) there is a web inside the engine case that needs tweaking. Not on the cover.
99+ TLS had the TLR clutch in them, but kept the cable actuation."I spent most of my money on Scotch, women and cigarettes. The rest I just wasted"
