new smell last nite
  • new smell last nite
    ok i was practicing some 1st gear power wheelies now that it'll actually do them and after a lil bit i started smelling something like a gun after it has unloaded a few rounds. gunpowder smell? i dont know if it was a car in front of me or what but i stopped doing it cause i thought it was mabey my clutch or something. any suggestions?
    Me and Joker have a small amout of coolant that runs out when we are doing wheelies. This might be the smell. Look on the right side of the bike, near the back of the belly pan for coolant stains.
    2003 TL1000R
      cool ill check that out whe i leave from work
        i get that too.
          Another one falls to the darkside. Before you know it you will be trying stand up wheelies. Clutch would smell like hot brakes, but since it is inside the engine you will get very little smell, not like a car. Coolant has a sweet smell and taste.
          Was the car ahead of you shooting at your
          Pictures
          Here's how it sounds.
            Hmmmm, are you sure it wasn't your breath blowing back in your face?
            Sorry, couldn't resist.
            If it ain't broke, lighten it.
            '97 TL1000s, '00 DRZ400s
              haha! good one
                I agree that it is probably coolant. You should probably rig something up to stop it from coming out of the overflow. I imagine though, if your anything like me, that the thrill of wheelies will call you and you will ride instead. Then you will do more and more wheelies. Spilling more and more coolant. Then one day you will stop and a light while out doing wheelies with your friends and they will all be looking around saying what is that smell. You'll say but secretely you will know. Then, after they keep asking and asking and asking about it you will say... "ITS COOLANT GOD DAMNIT, GET FUCKING OVER IT ALREADY" Then maybe you'll fix it over winter because its not really hurting anything.
                2003 Blue and White TL1000R (The faster colors) Yoshimura Ti Cans, TRE, Custom Homemade Fender Eliminator, Hammerit Carbon Look Intake Covers, PC II, Fan Switch Mod. Yellow Box, Nissin Brake Caliper and Goodridge SS Brake Lines.
                #1 STUNT FORUM SUPPORTER
                  Hahahahaa
                  My site.
                  www.tacoma.gixxer.com
                    Not clutch for sure. (Its sealed in the cases and doused with oil) Coolant usually smells like an overheating car, but it still could be the problem. Are you covering the rear brake?(And if so could it be dragging just a little?)Maybe you were behind a drive-by shooting
                    Stupidity is like chlorine for the gene pool.......
