On the new (aftermarket) signals, the black and white is the ground. I just want to make sure it's the same on the motorcycyle itself. (I looked in the shop manual PDF file and couldn't make a clear distinction.) Thanks in advance for the help.
Wiring question
Wiring question
Hi, I'm replacing my front turn signals. I'm not too familiar with electrical work, so I don't want to screw anything up. Is the black wire with the white stripe the ground wire? Or is the solid black wire the ground?
On the new (aftermarket) signals, the black and white is the ground. I just want to make sure it's the same on the motorcycyle itself. (I looked in the shop manual PDF file and couldn't make a clear distinction.) Thanks in advance for the help.Tags: None
just connect them like for like................
