New Clutch Master Cylinder
  • New Clutch Master Cylinder
    I want to replace my broken clutch MC with something trick. What should I use and where can I find it?
    Maybe a Radial Brembo Clutch Master? I'm not sure...
    I can tell you, however, that I do most of my riding on the road so please consider that when making your suggestions!
    Thanks fellow TLR/S lovers
    A TLS cable set-up
      I'd have to second that, would be cheaper than a replacement TLR item, it weighs less and it works as good or better.
      It's an easy conversion too.
      Crash Test Dummy
        Are there any benefits of cable over hydo?
        How do I do it?
          Only real benefit is that it saves a little weight and is a lot cheaper to replace if you ever bin it again. Replacement hydraulic clutch master cylinders are pretty pricey for TL's.
          They both work just as good as each other. I really don't think there is any difference in terms of performance between the hydraulic and the cable system.
          There are quite a few articles on the forums about the conversion. I should have written up a guide when we had ours all apart but was too slack
          Crash Test Dummy
            There is how to on here, and if you search the ezboard Doug just did one too.
            Doug on the EZBoard
            And on here
            another
              Thanks boys... i'll get reading
                We picked up a Busa master cylinder setup and will be tinkering with it over the winter. Much more "crashproof" than the flimsy plastic TLR stocker.
                Kim
                CCS AM #507
                Twilight Racing
                  Seen this? http://www.tlplanet.com/forums/showt...&threadid=9710
                    Is there such a thing? If so, would it necessary for that kinda money? I'm betting the TLS cable set-up would give a bit more feel than the TLR hydro...
                    Yes, economy and progressive action. No bleeding either... The downside to a cable is if you have a really hard clutch pull, but I doubt that is the case here.
