POS *&^%$ leaking tank...
I've had it. My TL's tank is leaking from the fuel pump gasket. Fixed it like 5 times now, new gasket the works, and the fuggin thing's still leaking...Tags: None
Okay, I posted too soon. Just checked the board and there are 3 other threads on leaking tanks.
So who's got the solution?
Had a similar problem with my SRAD GSX-R600. Took the fuel pump off to clean the filter cause it was dirty. Put the pump back in without the gasket and did up the bolts and THEN found the gasket. Realised that by putting the pump in without the gasket I had warped the opening in the tank. It leaked and leaked and leaked. Tried alot of things to sort it out. None worked. Was suggested I get the pump welded into the tank but that's not a solution. You'd be leaving the next owner a nasty surprise the first time he tries to clean the filter. Eventually had to bite the bullet and buy a 2nd hand tank.Jay
Black ones are faster
Originally posted by Tiller2nv
I had the same problem untill I read the Manual and followed the bolt pattern. Once I did that it was fine
Re: POS *&^%$ leaking tank...
Yup, I'm one of 'those' folk....
Finally having my mechanic work on it..
He's trying a different sealer this time.
brand new gasket, cleeeeeeeeaaaaaaaaannnnnn fuel pump opening, and it still leaks like a siv...
