TLR acting up
  • TLR acting up
    today on my way to school the TL was acting up a little bit. i was cruising down the street, in second i think, then i pull the clutch in to coast for a minute, when i let the clutch back out to go it got all herky jerky, and didn't seem like it wanted to go. i pulled the clutch in, reved it, and then went back on my way. the same thing happened on campus. i was doing a rolling slow down, in first gear to go, and it started jerkin again. clutch and rev. then right before i pull into the parking lot, i let the while i'm rolling, i start to let the clutch out and the moment it hits the friction point it stalls, i'm able to start it while still rolling, fires right up. when i went back to my bike to head to work it fired right up, and seemed to be fine. i'm just wondering what could have caused this behavior. mite have to send the tl to its room early tonite
    matt
    matt
    What mods?
    Anyway I'll give you the standard answer, check your TPS setting, make sure it's spot on. Do a search if you don't know how to do it, there is a lot of info on this board on how to do it.
      Could be running a bit rich and/or a fouled plug. Also check for water in your side stand switch (push it in and out a few times and listen for a squishing sound). TPS, and throttle body sync might help.
      Doc
      Geez my bike sounds funny now
        mods are yosh race slip ons. i have a feeling that it is running a bit rich, i'm gonna try and get a pc soon. i'm going to check the tps tomorrow. thanks for the replies.
        matt
        matt
