matt
TRE Installation
TRE Installation
i have a switchable TRE that is sittin on my desk at home. i don't hvae instructions for it. what i do have is instructions for a TRE on what looks like a GSXR. would i do the same thing as on the gixxer? thanks in advance.
mattmatt
Parting out 2 bikes. Let me know what you may need.Tags: None
Jeff's TRE? If it has the white clips, it gets installed on the right side of the bike, just inside the fairing. I took off the bottom fairing then removed enough (but not all) of the screws so I could pull the upper fairing away from the frame. You should be able to see the clips at that point. From there it is a matter of plug and play!
Originally posted by orange57
or how much does one of jeffs tre's cost?
matt
Jon must've beat me by 30seconds, I'm getting slow.
I meant the TLS / TLR plug is in a different location to the Gixxer ones, so don't use the Gixxer instructions to find the plug, it's on the opposite side of the bike.
Horkn, you've got all winter to it, don't be scared, just cut and splice your 2 wire job and add an earth"I spent most of my money on Scotch, women and cigarettes. The rest I just wasted"
its not a plug an play one, i am going to have to splice some wires. just wondering what wires those would be, either that, or how much does one of jeffs tre's cost?
matt
Black / white trace = earth
Red or pink = GPS / ECU signal
Blue = Neutral indicator."I spent most of my money on Scotch, women and cigarettes. The rest I just wasted"
Originally posted by jon super
$35 for the switched version on his site
mattmatt
