520 Steel Sprockets??
I hate wasting anymore $$ on Vortex's and I want to get the most out of this EK Chain.. Any recomendations on 520 NON ALUMINUM SprocketsI may go back to my 530 after this next one..
www.sportbiketracktime.com
Southern Division CoachTags: None
Originally posted by LeonTLR
Sprocket specialists makes one.www.sportbiketracktime.com
IIRC, there's a company that makes sprockets that has an aluminum carrier but steel teeth for better wear. i'll have to dig through another board to find the link to it.AFM #715
http://www.sprocketspecialists.com/h...ltstreet.shtml
I think the 97-00 GSXR 600 is the same as the TLR.
whats the difference between 520 and 530?and why?ohlins steering damper,ohlins rear shock,did x ring 530,motivation frame sliders,rocket throttle,LP carbon fiber clutch and brake levers,Yoshi SS full system,Teka,Jeff's TRE swtichable, aluimium alloy mash,radiator protector,scott oiler, Powerbronze windshield,denso iridium IU24A plugs, LP carbon tank protectors, good ridge SS brake and clutch lines,water wetter coolant,Afam +2 spocket, semi floating front disc, racetech rear full floater, pyramid CF rear hugger, MRA wind shield, K&N air filter, Joe v air box, swing arm sliders, Rear brake LED lights,rumble undertray.....more to come
520 is thinner than 530, there for it decreases weight. this means less spinning mass, decreasing the inertia of the sprockets. bottom line, its suppose to help you move faster. if i screwed this up will someone please correct it for me.
mattmatt
mattYou got it, acceleration is helped by less inertia, also there is less gyroscopic forces with less rotating mass, which helps with turning the bike in.
Can anyone honestly tell the difference :dunno Rossi might and it might even show up in his laptimes, but you or I :dunno"I spent most of my money on Scotch, women and cigarettes. The rest I just wasted"
but y do some ppl still chose to stick to the stock 530?ohlins steering damper,ohlins rear shock,did x ring 530,motivation frame sliders,rocket throttle,LP carbon fiber clutch and brake levers,Yoshi SS full system,Teka,Jeff's TRE swtichable, aluimium alloy mash,radiator protector,scott oiler, Powerbronze windshield,denso iridium IU24A plugs, LP carbon tank protectors, good ridge SS brake and clutch lines,water wetter coolant,Afam +2 spocket, semi floating front disc, racetech rear full floater, pyramid CF rear hugger, MRA wind shield, K&N air filter, Joe v air box, swing arm sliders, Rear brake LED lights,rumble undertray.....more to come
yeah.i realli wonder if there is a significant differencee when u ride itohlins steering damper,ohlins rear shock,did x ring 530,motivation frame sliders,rocket throttle,LP carbon fiber clutch and brake levers,Yoshi SS full system,Teka,Jeff's TRE swtichable, aluimium alloy mash,radiator protector,scott oiler, Powerbronze windshield,denso iridium IU24A plugs, LP carbon tank protectors, good ridge SS brake and clutch lines,water wetter coolant,Afam +2 spocket, semi floating front disc, racetech rear full floater, pyramid CF rear hugger, MRA wind shield, K&N air filter, Joe v air box, swing arm sliders, Rear brake LED lights,rumble undertray.....more to come
