TPS adjustment done.
  • TPS adjustment done.
    As much as I love tinkering with things, very seldom does something actually come together right the first time. Today may have been the exception. I spent yesterday running all over gods green earth looking from the right bit and I was beginning to think it maybe futile. After 45 miles of driving through suburbia and 4 stores (2 two of which were Sears) I was able to find the bit! It ended up being at a mom & pop run True Value hardware store which was recommended to me by a sales guy as Sears (and 200 feet from the first place I went). Since they had a few of them I pick up some extra (look for a post in the ‘For Sale’ section) because they can be so hard to find.
    Anyway…
    Found some time this morning to get things together to make the adjustments. I had watched the video (thanks Rupes) so I knew what to look for. The initial marking was in the middle at idle but did move to upper mark until ~2k RMP. A tap here, a and tap there and the next thing I know the damn thing is at the middle mark at 1200RPM and moves up at 1400 RPM! (Ok, so it was actually about 3 minutes of tapping) I tightened it down and check it again… Same thing. Too Easy.
    Has it made a change? I have no idea! I probably won’t have a chance to ride until sometime during the week. Oh well, least I know the TPS is calibrated correctly. Also for shits and giggles I changed the setting on my ATRE so gears 1 thru 4 are mapped to 6th this time.
    I found it fairly easy to do also. It seems Suzuki sent most of their bikes out un-adjusted as mine was just over 1900rpm before moving to the top mark.
    Carey
    ____________________________
    TLR is gone...V-Strom'in now.
      I just adjusted mine last wkend, it was WAY OFF, the bar wasnt even in the middle to start. After tweeking and adjusting for about 20min I got the right settings and WOW!!! What a huge difference, 3k rpm stumble is gone, much smoother all around. Now i'm sorry i waited so long to adjust this...
      Yeah its definately a great tune-up to do!
      <font SIZE="5" COLOR="red"><b><center> ~Alien_Tank </center></b></font>
      <hr SIZE="10" WIDTH="100%">
      -see ya!!!
      <BR><marquee BEHAVIOR="scroll" DIRECTION="right" LOOP="25" SCROLLAMOUNT="6" SCROLLDELAY="50"> </marquee>
        Where do I find this video?
        1999 B/W TLR, Yosh RS Full Exhaust, K&N Filter, Undertail, Zero Gravity Screen, Barnett springs, Tre, Pair Valve Mod.
            If it was in your ass you'd know where it was...
            2003 Blue and White TL1000R (The faster colors) Yoshimura Ti Cans, TRE, Custom Homemade Fender Eliminator, Hammerit Carbon Look Intake Covers, PC II, Fan Switch Mod. Yellow Box, Nissin Brake Caliper and Goodridge SS Brake Lines.
            #1 STUNT FORUM SUPPORTER
              Search for TPS and you should find it. I think someone has it hosted.
                Rupes has it on his site,
                Big Nig Rig has it hosted too.
                Bewarned it is 217mB
