yosh full system minus cans??
I don't see why not....
I had bought a used yosh full TI system that had went down on the right side. I was able to order the right side can and mid pipe for about 130 bucks from yoshimura. All you will need is the part numbers to each specific part. I'm sure one of the guys around here still has their instructions....I may not be Mr. Right, but I will have sex with you until he comes along...
You can make up adapters as well so that you can fit any standard TL bolt on mufflers onto the yoshi headers. Otherwise you are stuck ordering the actual yosh cans that come as part of a full exhaust.
Mine at the moment has yosh headers and leo-vince cans bolted on.Crash Test Dummy
I think Hindle used to make the header pipes too, then you could fit any cans you wanted. If they are still available, I was thinking of getting the Hindle headers and the Akro pipesSOLD! 2002 Suzuki TL1000R -Blue/White
I'm sure no matter what you would be better off buying a full system and then selling off the cans.2003 Blue and White TL1000R (The faster colors) Yoshimura Ti Cans, TRE, Custom Homemade Fender Eliminator, Hammerit Carbon Look Intake Covers, PC II, Fan Switch Mod. Yellow Box, Nissin Brake Caliper and Goodridge SS Brake Lines.
#1 STUNT FORUM SUPPORTER
I email this guy at Yosh.
Here's his address:
Leif Fleming [mailto:[email protected]]
It was about $538.00 for the pipes, then an adapter would be needed for the bolt ons.
BTW, I have a TL1000S so I don't know if your headers would be more or less...Just a few mods:
