*ping* Mr. brewer
  • *ping* Mr. brewer
    Jim I know you have the same setup as me and was wondering what #your running on your suspension. I have ohlins forks and shock and attack trees. Thanks
    WERA +CCS #920
    sponsors:
    www.Kneedraggers.com
    www.streetncomp.com
    1888fastlap.com
    www.pirelli.com
    www.vortexracing.com
    www.pit-bull.com
    www.sharkskinz.com
    www.vpracingfuels.com
    www.galfer.com
    Re: *ping* Mr. brewer
    Wow.. lesse if I can recall all this stuff.
    Forks: .95kg/mm springs w/oil @ 100mm, 2 lines showing above top triple clamps, #3 Attack offset, 30mm loaded sag, compression at 12 clicks, rebound at 10 clicks
    Shock: --gag-- I don't remember the spring rate --/gag-- 27mm loaded sag, compression at 12 clicks, rebound at 9 clicks.
    I weigh about 205lbs. with all of my junk on. I'm using a 120/75-17 front and a 195/60-420 rear so your ride height dimensions might be different if you're using different tires.
      I'm running super corsas w/ a 190-55 rear. how do you like the ohlins, I know most of the guys here love penske.
      WERA +CCS #920
      sponsors:
      www.streetncomp.com
      1888fastlap.com
      www.pirelli.com
      www.pit-bull.com
      www.sharkskinz.com
      www.galfer.com
        I'm ok with the Ohlins .. it's a hell of a lot better than the stock shock!! I wish it had ride height adjustment, but oh well ..
        I guess the Penske is good also, although I've beaten a number of Penske riders on the track, so who knows. I think either can work.
