Rear brake pressure question?
I can't help you Dave. I very rarely use my rear brake on the TL, only use it carrying a pillion or on the track, and I can lock it up on the track as it is usually nearly off the ground when I'm asking for it to help.
Normal street / twisty riding I'd have to say I've never locked the rear wheel with it. But it does feel shit come to think of it."I spent most of my money on Scotch, women and cigarettes. The rest I just wasted"
think its common never realy noticed it until my brother inlaw wanted to swap bikes I shot off on his GSXR1100 first time I had to use the rear, put the same force on it as I do on the TL and locked it up big time, don't think I've ever done it on the TL. not that I haven't triedA pat on the back is only a few centimetres from a kick in the butt
My friend stomped the rear brakes and locked the rear tire on his R6 on Friday and it ended up turning into a highside. It happened right in front of me too
. With that in mind you should be happy that your rear brake doesn't lock up.
2003 Blue and White TL1000R (The faster colors) Yoshimura Ti Cans, TRE, Custom Homemade Fender Eliminator, Hammerit Carbon Look Intake Covers, PC II, Fan Switch Mod. Yellow Box, Nissin Brake Caliper and Goodridge SS Brake Lines.
#1 STUNT FORUM SUPPORTER
Originally posted by TLRipley
At the MSF Basic RiderCourse, they have you lock-up the rear wheel so that you know how it feels -- then they tell you to never do it again. As someone mentioned previously, highsides and other unpleasant events can result.
Cant lock my rear either with the brake, but I have no problem doing it with the engine. Acctually, I think it´s kind of fun sliding with the rear before corners, and the engine have the right rev, so I think it is easier to meet with the trottle when going into and through the corner.
Did an accidental 10m rear lockup with the engine entering a roundabout (eh, what do you call those funny things??) yesterday. Infront of a "L" marked car...
Guess the teacher said a few word about bikers...TL1000R -99. Yellow/Black.
you got me all wrongI don`t usually lock my rear up when riding, unless absolutely necessary, it`s just that i had a ride on my mates gsxr1k and noticed the difference in the pressure needed to lock the rear. Did a couple of comparison runs, at about 10kmph, and his locked way easier than mine...thats all.
Thanks for the concern thoughDave
You should be able to (mechanically-wise) but like everyone said, why? I put a little air in the rear for mine so that it will be a bit more spongy and harder to lock up.It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt.
Mark Twain
well his prolly easier to lock up because a, gsxr's are getting the better tech, and b, cause its a lighter bike!
i don't use my rear...trail braking every now and then...but really i've though about taking it off cause its just straight useless. Engine breaking is a charm
btw, i dunno why you guys are getting all up about locking the rear....there's nothing wrong with locking the rear, its releasing the locked rear that's trouble and leads to highsides.
