pic whoring my new fender setup
wohoo, how's this look with a set of tiller gauges swapped in behind it.2000 TLS, bahama blue with guard rail mods, ProTek rearsets, Yosh Slipons, PCIII
2001 DRZ 400E M4 full system, Nstyle graphics, 320mm front rotor/17inch spoked rims on the way. Damn shippingTags: None
Gauges Thanks for helping me with resorting the wiring for the gauges2000 TLS, bahama blue with guard rail mods, ProTek rearsets, Yosh Slipons, PCIII
the tls makes such sweet street fighter.nice i likey alotMY MODS:
TO BE CONTINUED
it's broken off, I got the gauges with missing speedo needle, and broken face for 40 bucks off of ebay. new face was less than 40, and I'll pull the needle off my my stock TLS gauges. might also have to swap drives, but I hope not.
Also need to finish blacking out swingarm, tripple, and forks.
Just need to get some more epoxy paint. And I need to strip/redo the main frame on the right side, it didn't take right. Oh well, I'll try that eastwood spray stuff next, and just mask everything well. I have much better luck with the spray cans.2000 TLS, bahama blue with guard rail mods, ProTek rearsets, Yosh Slipons, PCIII
Sweet Ride
Looking like a true MonsterGalfer braided lines throughout, ATRE, UFO tailight, ET79 Undertail and Hugger, 520 16/39 Gold Chain combo, Full Yosh C/F exhuast, Corbin seat, Ohlins Steering Damper, Ohlins Rear Suspension, Tinted Double Bubble Windscreen, Sylvania Superwhites, Yosh Box Remapped and all protected by GORILLA Alarm System
Pro Tek, and they have held up very well. Both the left and right side were bent into the swingarm after this incedent, and we were able to bend them back out, and straighten the shifter/brake pedal, because they looked like modern art instead of a functional part of a motorcycle.
The right peg is ground partially off, but at over 40 bucks a peg I don't feel the need to replace it yet.2000 TLS, bahama blue with guard rail mods, ProTek rearsets, Yosh Slipons, PCIII
