911 Tiller in distress!!
  • 911 Tiller in distress!!
    Ok fella's help me with this question. I took the cover off of the beast tonight and noticed a small puddle of antifreeze on the ground. I traced it back to a small hole in the clutch cover just below one of the actual cover bolts. When I start the bike it continues to run out even quicker. Overflow is still full, which means its coming from the engine itself. This little hole doesn't appear to be threaded. Have I blown something out or does this little hole need a little bolt?
    That's a weep hole, leads to a cavity in the water pump between the water and oil seals so the fluids aren't mixed when a seal fails.
    Sounds like you water seal has failed. It's pretty common, just cleanup the shaft real good before reassembly.
      Is this something that I can do in the garage? Just order the seal and have at it? What kinda tips can you give me on this?
        I've never had to do one, plenty have and someone will explain it. But it didn't sound to difficult to do in posts I have read about it.
        Probably a job that needs the manual though.
          It is VERY EASY and you can di it in your garage. Just make sure you get all of the seals and take your time. If ya need help pm or email me!
