Anyone tried it?
Sprocket Turning
Sprocket Turning
Can you simply turn the rear or front sprocket around to use both sides? There is a groov on one side but I do not think it does anything. The stock sprocket has that rubber thing and looks like you can turn it around.
Anyone tried it?Tags: None
i turned my sprocket around.. now I have a speedy reverse an miles are comming off the clock2000 Race only TLR - Accel. Tech built GSXR1K forks w/triple, calipers/pads - Braking Wave Rotors - Full M4 (carbon) - Ohlins damper - Ohlins rear - pirelli tires - Graves fairing stay - Race tail complete with sub-frame - PCII - BMC filter - full Air box mod - Body Double race bodywork - GSXR1K front fender - Galfer/Goodridge lines - Woodcraft rearsets - complete - Woodcraft 50mm clip-ons - Complete front and rear brake levers w/ pazzo short levers red - Tre-Mod + Mod
turn
Well this came up because I have a sprocket that is perfect on one side of the tooth and just slightly starting to be rounded on the other side. I do not see why you could not turn it around? You could get twice the miles if you did it when the sprocket just started to wear. Bolt holes line up. Sprocket teeth line up.
Your teeth have all ready been stressed one way, now you want to put it on backwards and stress them the other way, that will weaken them up for a start. I'm betting you wont get anything close to half the wear compared to the wear vs. miles from it's original orientation.
And I'd have to agree with 996TLR aswell.
It's not worth the risk."I spent most of my money on Scotch, women and cigarettes. The rest I just wasted"
You have to be kidding you want to extend the life of your sprockets by turning them around. I just got my TLR but my previous ZX7 I had 5 sets of sprockets all different sizes. so I could change my riding style any day I wanted. Point here is they are cheap just splurge, while you are at it get a new and good chain, possibly get a conversion to save a few pounds.
anyway dont reuse the old one pleaseI'm so slow I think I'm first!!!!!!!
I'm having a hard time affording a pack of smokes and I sprung for new chain and sprokets. Trust us, it's not worth it. You'll bewhen you throw a chain in the middle of no where.
<a href="http://www.streetkore.net"><img src="http://www.sycink.com/images/SKlogoSigpic.jpg" ></a>
Cycle World and Salvage
(843) 747-2497
Sure.. You can reverse it.. It'll suck and teeth will pop off it like crazy leaving you stranded.. but technically you can do it..
It just that it's stupid and dangerous.I've got a huge penis, You've got a huge penis, even Tim over there, yup you guessed it, huge penis. Good, now that that's out of the way, let's go ride
stressed
All of the replies seem to forget that the sprocket I am talking about is not 10000 miles and worn down to nubs. I am talking about switching the sprocket every 2000 miles back and forth from new and getting equal wear. The sprocket is steel not aluminum and the teeth will not just come popping off. I knew that people would be against it. But the reasons are allonly one logical answer so far from tlsdoug.
Sorry to bother you with my unenlightened opinion..
A new sprocket is about $30-40, and lasts thousands of miles.. Who cares? buy a new one or waste your time every 2000 miles removing your rear, flipping everything, putting it back together and realigning it.
It's your call, have fun with it.I've got a huge penis, You've got a huge penis, even Tim over there, yup you guessed it, huge penis. Good, now that that's out of the way, let's go ride
After it starts to wear your chain wears with it. They wear into a pattern together. So when you flip it you will get about half the miles before it shows the same wear because the chain will quickly wear that side of the sprocket into the same pattern. Thats the reason you always change your sprockets with your chain. You can do as you suggested but as some have put it it's not worth the hassle for no more than a sprocket will cost you. I would not suggest it .RIP Ron
Sept. 12 2004
