Oh yeah, my seat flew off last night. Anyone seen one fly? I searched the ditches and the field for two hours. Thing must fly like a kite. Guess I'll find it when it's harvest time.
Rear Brake Problems
Rear Brake Problems
The rear brake on my TLR is having issues. Everytime that I depress the lever, there is nothing. Pump it back up and sure enough it works fine.....for about ten seconds. I have bled it repeatedly to no avail. The level is perfect and was perfect when the problem arose. If I am just cuising down the road it won't fade as quickly. If I am out wheelieing....it fades almost immeditely. Not good when you are tryin to learn to use the brake to contol wheelies.
Oh yeah, my seat flew off last night. Anyone seen one fly? I searched the ditches and the field for two hours. Thing must fly like a kite. Guess I'll find it when it's harvest time.Last edited by yeller_twin; 08-06-2003, 11:24 PM.Tags: None
No idea about the brake thing but welcome to the Planet
Sorry to hear bout your seat"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming WOW, what a RIDE!!"
Sorry about your seat..
On the brakes I would check the parts themselves to make sure the aren't leaking and that they maintain pressure. (I just rebuilt my Ninja M/C because of something like you are describing).
Oh.. and WELCOME to the PLANET!I've got a huge penis, You've got a huge penis, even Tim over there, yup you guessed it, huge penis. Good, now that that's out of the way, let's go ride
Sounds like a problem with your master cylinder.http://media.damnfunnypictures.com/dfp/fg_14.gif
Rear wheel or rotor isn't loose and banging the calliper piston back in too far?
Same for the caliper itself, if it is not secure it may move around and belt the pads and pistons back too.
:dunno That's all I can think of if it is fine when cruising but plays up when stunting."I spent most of my money on Scotch, women and cigarettes. The rest I just wasted"
Just from sitting today (rainy) the brake had lost its prime. I bled it one last time and got one small bubble out of the back bleeder. I watched the pads when I pushed the lever down and they moved quite a bit? Anyone know what color the fluid in the reservoir is suppose to be? Mine has a nice brown color.
The caliper and rotor are secure, but I never would have thought of that.
Found a replacement tail cowl. Got my old Genuine Suzuki tank bag out and strapped it on. Came out better than I thought it would. Thought there was room under the cowl...ha...I could stuff my helmet in there.
Brown?.. Uhh.. tan ish.. maybe? but not brown...
By the time it hits a deep amber color it's hosed... (soaked up to much moisture.. but then again.. it's supposed to do that..)I've got a huge penis, You've got a huge penis, even Tim over there, yup you guessed it, huge penis. Good, now that that's out of the way, let's go ride
Brake fluid is designed to suck moisture out of the system. (it's bad for parts, promotes corrosion, and isn't nice to brake "feel").
The main way to tell it's hosed is by color. Open a new bottle and compare.. You'll see.. I use the Motul 600 stuff works great.I've got a huge penis, You've got a huge penis, even Tim over there, yup you guessed it, huge penis. Good, now that that's out of the way, let's go ride
I re-built these brakes 4 times in the past month! if it's not leaking, it sounds like the secondary piston seal in the master, it's breaking down and letting fluid back thru it and causing your problem. This is just a good guess of course. I rebulidt mine today.
I also have a master clyinder if your in the market for one, having another caliper and master was very helpful in my long battle with mine.
Good luck!miketlr1000, fully chromed, yosh stainless, rennsports, Viper remote starter, custom 24v 100 led tail lights,
corbin, custom led blinkers, air tubes removed of the exhaust, 530 DID racing chain, air horns, rear view camera with LCD, ohlins rear shock 40 tooth sprocket.
