shifting with no clutch?
Here we go!!! One purpose of the clutch is to remove load from the motor. This in turn allows the engagment dogs to engage without being mashed together. This same principle can be applied to shutting the throttle down momentarily. By shutting the throttle down you remove load from the motor and presto you in the next gear. The technique for clutchless shifting is when you are ready to shift you apply pressure to the shift lever, and upon partially closing the throttle you will engage into the next gear. Is this harmful to the trans....no. Just as long as you are removing load from the engine so the engagement dogs aren't getting mashed together. Superbikes run electric shifters. Electric shifters are quicker than the technique previously described, because they can do full throttle shifts. Through a adujustable unit when the racer applies pressure to the shift lever the ignition is temporarily cut, again this removes load from the engine and allows the engagement dogs to engage just as they are intended too.
From what I know about it, it is not bad. I have been doing it occasionally for a few years. I have heard it saves on the clutch, but who knows. Usually, you just put some slight pressure on the shifter while accelerating and as soon as you get off the gas, it clicks right in.'98 TLS with a yellow box and some not-that-new tires.
SE WI
Here is a cool setup for one of you guys that is looking for their next project... the Yamaha FX bike has a fabricated bracket that trips the factory kickstand switch to kill the ignition temporarily for clutchless upshifts. saw it on amasuperbike.com i thinkBrad Wright
WERA NV #262
Sponsors:
Pirelli Tires
Vortex Racing
Pit Bull Motorcycle Stands
Jolly Boyz Racing-Misfits on Motorcycles
I do it on every ride and have done it on every bike I have ever owned and have never had a problem"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming WOW, what a RIDE!!"
Upshifting without pulling in the clutch will not hurt anything.
Downshifting is when you want to pull in the clutch.Kim
CCS AM #507
Twilight Racing
Racing motocross years ago, I never used the clutch except for starts. Even when I locked up the back wheel from braking for corners, letting off the brake always starts the engine and you what the throttle and go. probably wasn't good for the gear box, but you get around the track faster.Todd303
I've seen a spare rear brake switch hooked up to the shifter arm, being used to cut the ignition. Properly adjusted, it's a poor man's electric shifter! Wouldn't take a heck of a whole lot of work to do it either... Next mod perhaps?2001 TLS
Full M4, PCII, K&N Air Filter, SS Lines, 16T Front Sprocket, 180 Rear, HammerIT DB Screen, NWS Hugger
Downshifting is when you want to pull in the clutch.I've got a huge penis, You've got a huge penis, even Tim over there, yup you guessed it, huge penis. Good, now that that's out of the way, let's go ride
Originally posted by TLSBill
You have to shift like a manI don't apply any pressure until I cut the throttle:dunno that's when I kick it into the next gear. Never downshift without the clutch
I never use clutch on the DR's up or down:dunno seems fine to me.TLOTM:
i always upshift w/ no clutch except 1 > 2
downshift i use clutch. i don't blip to match revs unless i'm on the street. too much going on for the track to blip while grabbing a downshift and braking. i feather clutch out on trackAFM #715
