Fans not working.
Fans not working.
When are the two fans on both sides under the air duct ducts to the frame supposed to kick on. i turned the bike on and cranked it and they don't kick on. electrical problem? or do they only turn on when in gear? that doesn't seem right
Tags: None
Re: Fans not working.
Originally posted by carterink View PostWhen are the two fans on both sides under the air duct ducts to the frame supposed to kick on. i turned the bike on and cranked it and they don't kick on. electrical problem? or do they only turn on when in gear? that doesn't seem right
Yep, they're thermostatically controlled.
They automatically turn on when the bike is running excessively warm. The switch actuating the fans, assuming you have an R, is brown, visible in the middle fairing vent-hole on the right side. It is screwed into the radiator.
Many of us who live in warmer climates, or sit in traffic for prolonged periods will replace the switch with another that engages at lower temps, or install a manual switch on the handlbars.
http://www.tlplanet.com/forums/showthread.php?t=71981You do not talk about Fight Club....
If you see your temp getting up to 225 you should prolly do one of the mods mentioned. Thats much to warm fo my liking.TRE, Galfer Brake and Clutch Lines w/Dot 5, Airbox Mod, Yosh Exhaust, +2rear sprocket, Sprung for 240, GoPro
man i live in colorado. and i myself am strongly considering the fan switch mod ! another good suggestion for your tiller. imo.
I was getting worried for a while. It's Thursday here and I hadn't seen a post about fan operation / turn on temperature this week.
All is normal again."I spent most of my money on Scotch, women and cigarettes. The rest I just wasted"
LOL....Agreed but it is alarming the first time you look down and see 216. I live in the stix,184 constant with engine ice.TRE, Galfer Brake and Clutch Lines w/Dot 5, Airbox Mod, Yosh Exhaust, +2rear sprocket, Sprung for 240, GoPro
Yeah, in ga. It's HOT right now. And traffic. Not to mention my batteery died when I discoveried the park setting on accident and a friend l,eft the bike on after a jump trying the charge the battery. All he did was cook out ALL ofr my coolant. That and ridin in 110 heat has the frame cookin my legs so I'm lookin at coolin options. 225 is common for me
