Tire changing tools advice
  • Tire changing tools advice
    With three bikes in the garage now its time to get the right tools and start changing my own tires. For the people who already have the tools, what are the one to get?
    Bead breaker, tire irons, rim protectors, tire changing station possibly.... What other tools have you found handy for the job?
    Rich
    "insert snazzy sig here"
    Re: Tire changing tools advice
    wire brush soapy water and starting fluid last one is optional only used in extreme cases...
    age is a state of mind
    sigpic [IMG]
      I suppose starting fluid is to get the tire on the bead? Ive seen it work like a charm. Im also interested in some econo way to change my own tires.
      TRE, Galfer Brake and Clutch Lines w/Dot 5, Airbox Mod, Yosh Exhaust, +2rear sprocket, Sprung for 240, GoPro
        my brother and i use a big c- clamp and the spoons. but we have been talking about building a bead breaker, just havent gotten around to it yet.
          i built my own tire changer. it works about as fast as the no-mar tire changer, and it cost about $10 in material to make. that with some spoons, rim protectors and soapy water
            Rich
              any pics of the home made ver. i too would also like to not pay to get this done anymore and anything i can make is one step closer...
              sigpic [IMG]
                I used to use a vise for my old gs tires. but I dont think a 190 will fit in many vices out there. you could prolly use it for the front still. If I remember right one of the parts mags has all the tools and a hand operated lever style breaker thats pretty inexpensive.
                K&N ~ full stainless yosh ~ flush front signals ~ ideal cycle undertail ~ russell stainless front and rear lines ~ Barnett clutch springs ~ cheesey ebay hugger ~ fuel moto ATRE ~ euro right hand switch ~ speed metal shorty levers ~ Joe V airbox mod ~ flapper delete ~ +5+10+5 (thanks chuck!)
                  harbor freight has a decent setup for around 100 total...will break the bead and all....i use it and some tire irons...rim protectors...and soapy water...i suck at changing tires but it works for me..also for another 50 bucks they got a balancer...but there are other ways to balance if u dont wanna spend the $$$...good luck
                    Originally posted by DropKickChip
                    i'll have to take some, i thought i had one but i guess not
                      Uh.. Rednecktwin.... it also helps to have a WELDER and metal to weld one up with... ya know most of us dont have those tools.
                      I've used his rig.... work very well. He mounted it to a work table and it works quite well.
                      Hurry up with the pictures!!
