Oil cooler conection leak
Had a very small leak from the banjo conection on the oil cooler. When I unscrewed the hollow bolt I only found a sealing washer on the bottom, and according to the manual there should be one on both sides. Is it possible that the top washer is still stuck in the oil cooler and needs prying out. I can't see anything obvious. Has anyone had this problem?Tags: None
Re: Oil cooler conection leak
Its possible, as they're crush washers.
You should be able to see it if its there.
for the minimal cost you may as well just use new ones anyway.
Welcome to the site
Where in England are you?************************************************** **************************************************
My bike mod list - Click here
If its there it will be slightly proud of the housing . if not there will be a step down.www.cycleinnovations.com.au
