+ mod (plus moD) question
those of you who have done the + mod, where did you tap into the orange/white wire to the coils? i have the tank propped up and the only one i see readily accessible without removing the airbox is going into a plug that is mounted to the back side of the airbox. but the wire seems way too small of a gauge, i also see up near the handlebar controls a orange/white wire thats much thicker. where should i tap in? and how do i know which direction the ECU is vs which direction the coils are? thanks guys... simple mod shouldnt be so difficult hahaTags: None
Re: + mod (plus moD) question
I tapped in close to the coils and attached the relay to the loom.
And yes ,I took the air box off to do itFull Yosh
PC III
Penske shock
Braided lines
SteveTLS TRE
Rifleman 1/5
Pazzo levers
Vandriver tailrisers
Modified Buell footpegs
Custom Projector headlights
GSXR forks
TheRingin raised clipons
Ohlins steering damper
GSXR mirrors
TLOTM Sept 2011
BBOTM Nov 2011
